Power commander failure?
Just unplug it and plug ECM in stock. Bike may not run well depending on mods, but ou won't be stranded.
Sure, I've read a bunch of others in here over the yrs that's had issues with them.
They are a piggy back system and with any thing that an add on it can go bad.
Don't remember how many were stranded though.
Bike has 60k miles. PC-V installed ~ 35k 2 1/2 years ago. Never fail, yet. I did plug in a pair of X-ied's to the O2 pigtails and left them hanging. Figure just in case the PC-V fails, I can plug the O2 back in with the X-ied so it won't run as lean.
Had a buddies PCV fail on his Dyna
heard about a few others failing around here
quality control issue?
i have had a few with no Problems in past years
But this time went with a SE Pro Tuner
wont leave me stranded
Mine crapped the bed after i washed it once.... If they get really wet they can fail. I just pulled it off and ran the bike without it for a day or two till it was completely dry and put it back on.... Ran fine after that.
Dialectric grease on the connectors will keep water from getting n there under most circumstances - the unit itself is supposed to be waterproof. The thing is to make sure its all tucked away properly and dont hit it directly with the hose (like I did :-(
