Latch ideas for aluminum solo swing arm box project????
So I am going to install a SS piano hinge but I need ideas and links for a latch idea. Im looking at a few. One thing I dont like is the latches will have to be at the same angle as the lid which might look off. Heres a few im looking at.
Here is the box so far.
May be a dumb question but is the right side of the lid going to be bent down like the left? Just curious.
I have no opinion on the lid, I am fine with whatever you decide to go with. Lol
No. Just the front. It will extend past the box lip though. Didnt see an advantage to that plus it could complicate a latch mount.
Hay if you are going to mount your plate to the rear I need to flush that rear over hang. Glad you said you are going to mount a plate back there.
Working on that. If its on the side it will be at an ankle to match the lid. I think it will look off. Could mount it on the front or do a key'd barrel tool box type latch. Thats why I started this thread. Spit ballin ideas.
Or cut a small half inch by 1/4 inch slot in the back of the box.
Weld this bracket inside the lid on one end or the other.
Make the piece sticking through curved instead of straight like in my drawing.
Rivet the arm to the mount bracket, keep it loose so that it will move.
To open just push up the tab sticking through the back.
It would also lock up with the second slot.
It would not need to be near a big as my drawing.
