5'x8' utility trailer
So I'm getting out of the military and moving back to Florida from Maryland and I don't trust the military movers to move my two sportsters. I looked at renting a trailer from Uhaul but they want as much as I could buy a small trailer for. So that is what I'm thinking of doing. Buying a 5'x8' utility trailer with a built in ramp, adding chocks and tie downs and maybe a plywood floor. Do you guys think this trailer would work? I would load one facing forward and one backwards.
It will be tight but doable. I have a 5X10 landscape trlr with folding eye bolts on the floor and wheel hoop for the front wheel. Plenty of room for one bike. Sporties are skinny but I wouldn't put two baggers in.
The military will pay for the rental trailer on a DITY move rather than buying one (unless you want one).
I'd never let some of the movers that moved me so much as look at my bikes no less handle them.
No they won't pay for the trailer bc they are paying to move the rest of our stuff. I was told by them that the only way they would cover it is if I moved it with the rest of the stuff.
There should be a partial DITY move that should cover this - unless something's changed in the 11 years since I retired.
Most stuff goes with the contract movers, and you still get some reimbursement for moving some stuff yourself - and it should be the things that shouldn't be trusted to the movers anyways - family heirlooms, guns, bikes, etc.
Allowances depend a lot upon rank - Junior enlisteds don't get much help in terms of special treatment, unfortunately, especially if moving more than one vehicle or a family's worth of stuff. The more rank you have, the more they expect you to own and need to move. Regardless, double check with the Transportation Officer before you give up on the idea of getting some reimbursement for hauling the bikes yourself.
I have a 5 x 10 utility trailer with a ramp. I don't see two bikes fitting on there very easily.
How much does uhaul want for a one way rental? A utility trailer will be about four hundred dollars, plus costs of the chocks.
Buy/rent the trailer. Measure empty at departure location and measure empty at destination. You'll get some compensation.
Find out what the max DITY reimbursement weight is then max it out. I did that on a truck I rented. When I got to the destination I had it weighed still full and found out I was short about 500 pounds. I asked this farmer I knew if I could borrow some tractor front end weights and whatever else was heavy and I loaded it up and re weighed it.
They might not pay for a DITY if it's going to the same location as the main shipment. I did some DITYs when PCSing - DITY went to different location than the PCS move. Use an address down the street, across town or where ever for the DITY and you can probably get them to cover it. If they question it, just tell them the bikes aren't going to the same place as the rest of your stuff.
I had a 7x16 enclosed. Now I have a 7x12 dump trailer that I'll build an enclosure for.
