slip-on clamp question
I've got to pull the slip-on mufflers off the headers on my Eglide in order to slack the drive belt a bit. It's a bit snug right now. The service manual says to replace the clamps that hold the slip-ons to the headers. I'm having a hard time understanding why I have to do this.
Has anyone re-used the clamps? Were there any problems or is this just the Moco trying to sell parts???
I re-used mine 3 or 4 times, never had a problem, they will be used plenty more times yet, easy money for the moco to suggest replacing them every time.
I used to reuse mine until I almost lost one of my Slip Ons. If you can afford the $1.50 for the clamp at any dealer...I'd do it. The clamps are ment to be one time only use...meaning once their tightened...they're on. If you loosen them then you are not supposed to be able to get as tight a seal the next time. Now, you will be able to torq them the the necessary value, but the metal stretches out and it won't be as tight because the bolts will bottom out against the spacer in the middle of the clamp. Sounds contrary to logic, but I did measure the old one vs. the new one...it was 3/8" longer than the new one after it's 3rd use. Defective part...I don't know.
Now, this only happened to one of the two that I'd worked on, but when the one of the Slipons nearly fell off, I replaces both of them right away. No issues since.
Up to you...this was just my experience.
I recently added a set of Slip ons and the dealer told me to replace the clamps...the new slip ons came with new clamps but they were garbage so I reused my factory clamps, so far no issues but I do believe I over torqued them after reading this forum.
You can re-use them all you want, it's your choice. FSM says "new ones every time" for a reason - and it's not to add profit.
Yup re-using them may work for you. It worked for me, too, 3 or 4 times - right up to the point where I had to drive back and pick up a beat-up, road-rashed SE slip-on and drive 45 miles with it bungee'd to the sissy bar on my old Low-Rider.
Yup, I have a torque wrench. Yup, I know how to use it. Yup, I still have a couple of brandy-new clamps in my tool box from that bike... Pick something else to cheap-out on would be my advice.
I swap my slip ons at least a couple of times a year. Sometime I like the Rineharts,
sometimes the SE's. Been doing this for several years now, and have not had one
loosen up yet. I do tighten the hell out of them though, they are not bottoming out either.
Same clamps that came with the bike new in 05.
Your mileage my vary.
