power vision help
Old 06-26-2014, 05:06 PM
buttmonkey's Avatar
buttmonkey
buttmonkey is offline
Default power vision help
Need a power vision map.
I am looking for a map for the 09 Softail family.
Arlen Ness Big Sucker
Mid-range Slipon mufflers
Andrews 48h cams
I can't find anything close on the Dynojet website.
Anything close will give me a starting point. I have a barley rideable map, but, when I auto tune it tunes gets worse each progressive build.
I auto tuned 3 times-VE table only. Engine runs decent, but with major pinging.
Auto tune with only timing feature active, engine gets so bad will not run.
Auto tune with both active, engine starts skipping, backfiring and flooding.
Any help will be greatly appreciated.
Old 06-26-2014, 06:59 PM
Afrobaron's Avatar
Afrobaron
Afrobaron is offline
Call dynoJet and tell them what you posted. I bet they have something that will help you out.
Old 06-26-2014, 10:14 PM
Falcon195's Avatar
Falcon195
Falcon195 is offline
Ah the advantages of buying your PV from Fuelmoto.
If you purchased your PV from Fuelmoto they would engineer custom maps for no charge.
Try calling Fuelmoto and see what they would charge for a custom map for your application.
Old 06-27-2014, 03:13 PM
buttmonkey's Avatar
buttmonkey
AH, I did buy the power vision from Fuelmoto. That was 5 bikes ago. My riding buddies bought the extra license for multiple bikes. I don't think it's Fuelmoto's problem to help us out. I'm sure they have enough first time customers to keep their plate full. As many power visions as are out there, someone has a good map for our problem.
Old 06-27-2014, 07:54 PM
skratch's Avatar
skratch
skratch is offline
Received 4,193 Likes on 2,457 Posts
doesn't matter. fuelmoto has lifetime map support.
Old 06-27-2014, 09:17 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
AH, I did buy the power vision from Fuelmoto. That was 5 bikes ago...
Fickle much?
The Power Vision only came out a couple years ago. Are you sure you don't mean Power Commander? Same company, similar name, different animal...
Old 06-27-2014, 09:21 PM
Falcon195's Avatar
Falcon195
So let me see. You bought the PV from Fuelmoto (which has lifetime map support) but you rather ask someone here on the forums for a map that just happens to meet your bikes criteria.
OK.
Old 06-28-2014, 08:36 AM
rockerz's Avatar
rockerz
rockerz is offline
Call fuel moto, you can buy the license for multiple bikes 200.00 & they will likely provide you with the correct mapping. That's what I did on both my bikes.
Old 06-28-2014, 01:38 PM
JMC22's Avatar
JMC22
JMC22 is offline
As others have already said but it's worth repeating - if you really did buy your PV from Fuelmoto, and you still have an active license, then they will be more than happy to help you and build you the map you need.
I contacted them the other week, told them I liked the one map they supplied me but didn't like how my O2 sensors would tweak the map after I road about 50-75 miles - as I would then have to reflash it again - they sent me a custom map to stop that - problem solved in less than 24 hrs
Don't undersell this company - there are many more people that love their product than not on this forum, I being one of them
Old 06-28-2014, 01:58 PM
RJHD's Avatar
RJHD
RJHD is offline
Not saying Fuelmoto isn't a good company, but really? They are NOT the only PV dealer. I bought mine from another and Dynojet helped me out with all the info I needed. They adjusted and tweaked my map to eliminate some decel pop after I auto tuned and my bike bike runs super. No decel pop and runs cool and strong.
Now I have the PV mounted on the bike, (never thought I would) and love it. Pretty nice being able to monitor engine parameters.
Quick Reply: power vision help
