Accessory power on a Road King
Received 5,202 Likes
I am looking for a place to put a power outlet for charging etc.
Where have you attached one if you have it
what kind of "power" charging an usb device , or a lighter plug? I have mounted a lighter plug in my saddlebag , but if you wanting more accesable, there are usb outlets that can be mounted to the handlebars o a clamp on lighter plug pod that clamps on the handle bars but its a lot more bulky.
Look on the back of your headlight for a pair of wires coming off of it. Orange/white stripe and black. You can go to a auto parts place and buy a 12v receptacle (looks like a cig lighter) and use a usb adaper to charge your device. When using these wires from your headlight, if the headlight is on, you have power, headlight off, no power! I bought a 12v socket from an auto parts place for $8 or Powerlet sells one for $100. I wire tied my socket to the right of the trees. Right there in front of me......
I bought a lighter plug from batteries plus for my wife's King. It plugs into the battery tender plug when you are not charging the bike. It comes with a 6' cord. You can put it anywhere on the bike. Hers is zip tied to the clutch cable down by the base of the triple tree.
I have a Deltran battery tender with the cables permanently mounted to the battery. I recently bought this adapter which plugs directly into the cable ends. It allows me to charge my phone, I-pod etc.
http://www.ebay.com/itm/271429682772...84.m1439.l2649
Don't dick around. Call a Harley dealer,tell 'em you want the power cord receptacle that mounts on the top of the side cover. Comes with a template for layout. Just don't use the template blindly,check that it clears everything behind the cover. Neat,clean,plugs right into an open 4 pin connector on the front side of your battery,and can be turned on and off with the left side toggle switch. You can also get a "Y" splitter for the connector if you want another accessory. Search "12 Volt Power Outlet" on the forum,step by step install with pics.,plus the Harley part number.
