Torque wrench help
Torque wrench help
I am embarrassed to ask this question, but I'm of the female gender and while I know about basic tools, I need help in getting information about special items. I want to get my husband a few tools that would be useful on our bikes. He has lots of wrenches and sockets, both metric and standard, from all of his farming equipment maintenance, but he doesn't have a torque wrench. So far, it's just been by feel. I would like to get him a real torque wrench. Can y'all suggest what drive, foot-lb range, brand, etc. that would be most useful. They don't require special sockets do they? Any help here is greatly appreciated. Oh, and any other motorcycle tool that any of you have found to be of great benefit to suggest would also be appreciated.
Received 4,929 Likes
Keep it simple, go to Sears/Craftsman and get:
1- foot-pound wrench (probably will be 1/2" drive)
2- inch-pound wrench (probably will be 3/8" drive)
They use standard sockets and extension etc. They have a variety based on cost, pick out what fits your budget.
You are a good wife.
For my money I would get:
http://www.sears.com/craftsman-micro...1&blockType=G1
http://www.sears.com/craftsman-micro...3&blockType=G3
They have more expensive, but I have these for well over 10 years and they get the job done. Follow the links and you will see the ranges.
For the smallest nuts/bolts on a bike, the torque setting requirements can go as low as 30 or 40 inch-pounds, so you would need the torque wrench that measures in in-lbs to go down around that range.
The two suggestions that Architect posted would be great!
If you are just going to get him one torque wrench; one with a 3/8" drive measured in ft/lbs will be the most commonly used on his/all bikes. If he is going to be doing axles and work in the primary (clutches and compensators) a 1/2" drive that will do 100+ ft/lbs will be needed as well. The last one to get would be a 1/4" drive in in/lbs...The Craftsman torque wrenches are good for the money and they have a lifetime warranty. I currently have 3 sizes in the Kobalt brand from Lowes. When they are on sale they are hard to beat for the price and also have a lifetime warranty. I got all three of mine for less than one of the big tool truck brands (cornwell, mac, snap-on, etc.) I could not bring myself to drop $300+ on a single torque wrench. I am sure they are better quality, but if not using them multiple times a day, every day, I don't see the need. Mine have worked for years now and when I sent them to be calibrated last time they were still in spec.
I would read his shop manual and see what torque settings are needed and then you will know what ranges to buy. You definitely cannot get by with just one torque wrench. You will need a 3/8" and a 1/2". The 3/8", properly bought will go low enough but not high enough. The 1/2" will go high enough but not low enough. Do NOT get a cheap one. Craftsman are ok, but don't get a Chinese one just because they are cheap. Accuracy is critical. The ones that are certain to not go out of spec are 'bar' types rather than 'click' types. I use my bar ones to check my click ones and they can be way out. However, the bar ones can be hard to read if you can't get in a position to read the pointer to the numbers. Happy shopping.
