Clear see-thru air cleaner cover DIY mod
Old 06-30-2013, 04:23 PM
knightenforcer's Avatar
knightenforcer
knightenforcer is offline
BTW, use only blue loctite!
I know the pic of the screws looks like red loctite, but it's actually
red marker I used when I was gauging the depth and marking the template
Old 09-29-2015, 01:27 PM
hsr's Avatar
hsr
hsr is offline
Originally Posted by knightenforcer
I found a suitable clear polycarbonate material made by Bayer, it's called "makrolon" and it has a good heat resistance and strength. I found an ebay seller that sells them in 6" diameter so I ordered a few (in case I make mistakes).
knightenforcer,
Awesome mod, but you know already know that! Do you have any info on the eBay seller that you ordered the makrolon from? Not finding any rounds on eBay or readily obvious on the net.
Thanks in advance!
Old 10-07-2015, 06:17 PM
knightenforcer
Hey guys, It's been awhile and I did get some of your PMs. I no longer have the bike, I traded more than a year ago.
Regarding the questions on where I got the covers I dug deep into my old ebay purchases and I found the ebay seller, the ID is:"imagebyroberts2"
Not sure if she is still selling the Polycarbonate pre-cut pieces (bayer makrolon).
Hope this helps and Good Luck guys!
Old 10-08-2015, 06:44 AM
hsr's Avatar
hsr
hsr is offline
John,
Thank you again for the eBay seller info. Emailed him last evening and here is the response I received:
Hi Jeff,
Welcome back! Yes, we can supply Makrolon, just haven't listed any for awhile. It is the same price as the acrylic, so if you need just a few, buy the acrylic and send a note to remind us that you want the poly instead. If you need a quantity, let us know and we'll set up a special order procedure for you.
Thank you for your business,
Dennis
I'm going to order today and hope this also helps someone else out. Thanks for posting this mod!
Old 10-15-2015, 09:36 AM
hsr's Avatar
hsr
hsr is offline
Received my Makrolon order on Tuesday. Five days from Colorado to Michigan with a weekend and Columbus Day thrown in. Not too bad. $10.89 for two 1/4" x Ø6.0" pieces shipped.
dysfunction1
06-21-2019 11:54 AM
rockon
05-05-2014 03:43 PM
knightenforcer
07-01-2013 09:10 PM
bobros
07-05-2006 10:49 AM
DanDeuce
Exhaust System Topics
12-20-2005 11:57 PM
Quick Reply: Clear see-thru air cleaner cover DIY mod
