what's wrong with my sporty?
Ok so determined that the plugs and writing are good. Pulled the carb and going to have it rebuilt as there seems to be gas mixed in with the oil. Hopefully that's due to the carb not closing properly and leaking gas down into the system and not an issue with the piston rings. Should have the carb back and reinstalled Sat or Sun. I'll update once I've got it back in and new oil in as well to see if the issue is resolved.
Ok got the rebuilt carb back and installed. Initially after putting the carb in the bike was only running on one cylinder and even after verifying both plugs were sparking still had the issue. Turns out one of the plugs even though it was sparking was bad. Installed new plugs and after tuning the carb the bike is running quite well. There's still one problem left at this point.
As I believe I mentioned before the oil smelled like there was gas in it so I drained it while carb was out getting rebuilt and put fresh oil in after installing the rebuilt carb. After running the bike for 2 days(approx 80 miles give or take) it smells like fuel again in the oil. Any suggestions on what's causing this and next way to check/find this issue.
Thanks for all the help guys, you've helped increase my knowledge on my bike and while I hate that I'm having issues I'm enjoying working on the bike.
