shifter too high
shifter too high
hello,
does anyone know if the toe shifter can be rotated down on the shaft that shifts gears? the problem i am having is that i must lift my whole leg up to down shift and my left hip is just not what it use to be. the heal shifter is okay to up shift it is only the toe shifter. if it can be rotated forward and down i will then not have to lift my leg off the floor board.
thanks,
david
socal
thanks,
david
socal
yes
The shift lever is mounted on a splined shaft. You just remove the allen bolt that clamps it on and pull it out, then rotate it down one spline at a time until you like where it is. Then, reinstall the allen bolt and you are good to go. I have done this on many bikes and my wife's trike.
They make a chrome cover to replace the heal shifter. I have one on mine, because I dont use it either.
