Going The Trailer Route....have questions
I used to have a single wheel inline trailer on a bike I used to own. It worked beautifully, tracked nicely, and when you leaned the bike over on it's side stand the trailer would lean as well.
I just picked up a used Kuryakyn hitch for my 07 FLHT. I has an 1 7/8" ball. Most of the used trailers I see for sale are two wheeled. Is that a problem for towing, I mean it's natural that the bike leans in the curves a bit, and what about parking on your side stand. Would the trailer bind? I did see something mentioned somewhere about some kind of a swivel hitch but I can't visualize how it would work. I imagine it would just bolt on to the tongue like a regular hitch. Does anyone have any info, pics, or links?
And don't get me started on 4-wire vs. 5-wire setups. I guess I'll figure that out once I've picked up a used trailer and seen how it's equipped.
Jim
Jim
i never pulled a trailer on a bike before but I'd have to assume that there would be enough flex on the ball for it not to bind, i mean the hitch ball is designed to move in the coupling hitch of the trailer for curves and uneven terrain maybe I'm wrong and if so id like to know cause I'm thinking about one for my softail for cross country trips
I have pulled this rig thousands of miles, no swivel hitch, no problems. The ball is designed to rotate inside the coupler. I always put a light coat of grease on the ball before every trip. You can do a swivel hitch for peace of mind, I have not found it necessary.
It is a Harbor Freight Tag-a-long trailer. Less than $400 with coupon. It pulls very very easy, I rarely know it's back there. You can spend more money but this trailer does the job very well. The tail lights are junk, swap them out for LEDs.
The Harbor Freight trailer shown below is a great little trailer...it's 4-wire, which means you'll have to add brake lights or running lights in the back to accommodate the 5-wire m/c setup and add a 5-wire round plug to both bike and trailer (same pattern). Buchtec is a $ brand (elite) and doesn't have anymore pulling clout than the HF trailer for less $.
Final Worry
But....I am still leery about the hitch setup for cornering. I mean I hit the curves at quite an angle and I don't know about how much the standard hitch allows for side to side tilting. I see mention of Bushtec and Dauntless, does anyone know of where I could get a swivel type hitch in Canada? Crappy Tire doesn't sell them.
Jim
