help me out
help me out
My 2011 street glide will not start. I have a new battery with a tender on it. When I turn my select switch to ignition nothing but the oil light turns on. Can't even hear fuel pump. But I do hear a click click noise. That might be yhe pump, not positive. I turn the selector switch to Access my radio comes on. Need ideas to fix problem. Any help would be great. Thanks
double checked
Thank you for your help. I should have been a little more descriptive in the explanation.but thank you. Sometimes we miss the obvious. I have the run/off switch to run position the selector switch to ignition position. With both in the correct position, two lights appear. The red oil light comes on as well as the green neutral light. I elected not to have an alarm installed on my bike so therefore i did not receive a key fob. If u have any other suggestions I would love to hear them. Thank you once again.
