PCV Map for 117"
Any map for a 117" or even a 120" will work for the heat cycling.....I just need to be in the ballpark, the maps for '05 bikes only go up to 103" from my stock 88" and that is going to be too far off...here are specs since you asked:
117" (4-3/8"x4-1/8)
10.5:1 compression
Feuling 594's (gear drive)
CNC'd heads (2.020"intake 1.650"exhaust valves)
HPI 55/58mm maxflow throttle body
5.3 gram injectors
39" Samson Cholos
Ness Big Sucker (Stage 2)
117" (4-3/8"x4-1/8)
10.5:1 compression
5.3 gram injectors
39" Samson Cholos
Here is a map that should work. It does make a difference what year the bike is. If I had sent you one for a 08 up it wouldn't have been compatible on your bike as different software strategy. It is plenty rich and shouldn't hurt anything. If idle too rich let me know and will fix. Just change the .docx to a .pvm and it will open in PCV Good luck! Looks like a strong build.
Cheezyrider
09-18-2010 02:31 PM
