Autotune module question.
I think you need another cable to make it work. FM or Dyna Jet has them. You do know it doesn't work real time, just when you are in Autotune Pro to create a new map. You can also do data logs and it will give you data as to the actual AFR at any given point and can tune from that if you like.
The only difference between the PV1 and PV2 is the 1 is for 4 pin diagnostics plug and the 2 is for the 6 pin newer models. The autotune hooks directly to the PV and not the ECM or Canbus controller. My recommendation would be to talk to DynaJet or FM. Either one has an email support.
