pc-v map?
pc-v map?
installed a big sucker air cleaner this afternoon, fairly simple and straight forward. Debating if I'll use the football cover, you do hear the air being sucked in when laying on the throttle.
Setup:stock decatted headers, CFR slip ons, big sucker air cleaner
As for the PC-V map, currently using the following:
#046: CFR slip ons without insert, screamin eagle air filter
Sounds solid and not much decel , not much popping from what I've noticed so far. Suggestions thoughts on which map to use
