Won't start, disconnect/reconnect the fuel line and it starts
Title pretty much says it all. 07 Electra Glide. This has happened twice, bike keeps cranking but never starts. If I disconnect the fuel line and reconnect it the bike will start up like normal. Why does it do that? Is that an indicator that something is wrong?
Ok, so she stranded me again today. Today I road in to a doctors appointment, was there for about 30 minutes, came back out and the bike wont start. I've tried to do my research but can't find anything. It has a new battery, I can hear the fuel pump turn on and it just keeps turning over to no avail. I disconnected the fuel line on the back left underside of the tank, let some gas run out and some trash came out with it, looked like dirt or maybe a totally deteriorated O-ring. Still wouldn't start, I let it sit for like 10 minutes and it fired up.
I'm perplexed. The only thing I can find online is about people who's fuel pump will not turn on, mine does turn on and it still wont start.
There should not be anything else other than gas coming out of the valve. If the pump continues to run then the fuel system is not reaching the proper pressure. I would suspect that there is something that has deteriorated in the valve or the tank that is obstructing fuel flow, or there is a hole in the system. Look inside the tank when it is empty. The hose from the fuel pump to the filter will sometimes develop a hole in it. You may have to remove the hose to properly inspect it. The liner in the tank could be peeling off. The o-ring in the check valve could have deteriorated. The filter could be clogged.
A bad o-ring below the piston wont stop the fuel transfer from the upper to lower fitting but if its bad it wont shut off when disconnected. Sometimes what happens on the fittings is the ***** get worn or they wear a spot in the lower fitting and that allows the lower part to not engage properly in the upper part to allow the fuel transfer. I worked where these are made . On some models and I cant tell you which ones H/D actually went from 3 ***** to 6 ***** to better hold the connectors together for that reason. If its not leaking when connected one thing you could try is removing the o-rings and pistons out of both the upper and the lower fittings and then reconnecting them keeping in mind the larger o-ring looking up into the tank fitting needs to stay as that seals around the black lower fitting to stop the leakage when connected. Be careful you dont loose the pistons or springs. If it runs after that then you know there is a problem with the fittings themselves.
REMEMBER THERE MAY BE PRESSURE IN THE FUEL LINES.
Buy the new one and be done with the intermittent problems.
