Intermittent low idle ?
It started this spring it rarely did it every other ride which haven't been many this year. But today it died a few times on me at a stop, it gets down low and dies. if I keep a little throttle at a stop it is fine runs good other than that, after I got home it was idling fine and did a couple of restarts a few times and was running normal. I changed the fuel filter and fuel lines to the throttle body 8000 miles ago. Is this a fuel pump problem or regulator? how can I tell, bike now has 33000 miles. Anyone have a idea? I was thinking of changing the fuel pump and maybe upgrading the reg to a little higher psi, and I guess I would change the filter again while its apart?
I was getting the same thing on an '07 FLHTCU. It would intermittently idle so low that it would just die when you came to a stop. I was not getting a check engine light, but it was pulling a P0152 code, rear cylinder O2 sensor running rich. I checked and cleaned the idle air control, new air filter, new plugs (28,000 miles at the time) didn't make any difference. Finally took it over to the local Harley shop and of course they could not get it to show up. And ESP would not replace the O2 sensor. So I did it myself on my own nickel, (both front and rear O2 sensors) have not had a reoccurrence since, and I check for codes after every ride. I'm certainly not well versed in fuel injection systems, but it seems to me if the O2 sensor was showing a rich indication, the ECM would try to compensate by lowering fuel mixture to the extent possible, creating the low idle condition. Anyway like I said, it's been 6,000 miles since I had them change out the O2 sensors and I've not had a reoccurrence.
Last edited by Ezridr60; 11-06-2015 at 06:56 PM. Reason: clarification, O2 sensor was showing a rich mixture
