Any one have map for fuel moto micro efi: 103dyna v&h short shots and hd stage one?
Bought the bike a year ago from a guy who i dont think even knew the tuner was on it... Therefor ive always been a little skeptical of the mapping, unfortunately fuel moto wont give me a map without proof of having bought it from them...
Looking for map download for hd brand stage one aircleaner and v&h short shots on 103ci dyna
try posting on the "v-twinforum" in the "efi-maps-calibrations" section and ask for a map from DynoJet.
You can import a power commander V map into the micro EFI.
However, take note: When you load the map into the Micro EFI it WILL Switch front and rear cyl maps. I have made them aware of the issue but no one there seems to care. Same issue when downloading maps from FuelMoto.
The workaround is simple. Load the map to the MicroEFI, Then download it from the MicroEFI. The frnt and rear maps will have switched. Open the map in their software and copy(Right click, select all) the Front cyl Map and paste the map to the rear cyl. Save file as a different name. Then open the originally saved file, copy the REAR cyl map. Open the the map you just saved and copy to the front cyl. Save and download to the MicroEFI. This cyl switching of maps only happens the first time you load a map into the MicroEFI. I went back and forth with FuelMoto and Dynojet for quite sometime with no results as to a firmware update to correct this issue.
Road Star
09-25-2013 09:10 AM
Justinf74
02-27-2012 08:30 PM
