The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Pcv with auto tune issues.
Old 12-24-2015, 08:58 PM
Kburgad's Avatar
Kburgad
Kburgad is offline
Default Pcv with auto tune issues.
Had a power commander v for the last couple of riding months. Worked fine as far as I remember was using a canned map. Got a used auto tune. Installed now I've got no engine temp reading with my laptop except for a half second after starting up. Then drops back to zero. Enabled auto tune after 60 seconds for right now. Afr 2 starts to change but aft 1 stays at 9.99 thought sensor was bad swapped sensors. Same thing. Updated pcv with newest firmware and reloaded map. No change. Sensor module labeled for frt sensor blinks 1 time every couple of seconds, sensor rear stays on steady. Terminating plug installed all cables installed all the way. Checked connections from sensor harnesses to modules.
Any ideas?
Was gonna call dynojet but got busy at work.
Old 12-25-2015, 09:48 AM
whittlebeast's Avatar
whittlebeast
whittlebeast is offline
Check that all the wires are tight in the screw down connections. Also check that all of the wires ohm out end to end.
Old 03-27-2017, 12:03 AM
knife_edge's Avatar
knife_edge
knife_edge is offline
Any ideas?
Did you ever resolved the issues you had with your auto tune? I am having the same problems.
scotracy
03-09-2012 12:36 PM
sudbury2010glide
Exhaust System Topics
10-07-2011 09:34 PM
bobernet
08-03-2011 06:08 PM
All Aces
21
07-21-2010 01:08 PM
magnethead
05-29-2009 06:04 AM
Quick Reply: DYNOJET: Pcv with auto tune issues.
