Have I fried my ECM?
#51
#53
My problems started with intermittent hesitation and surgeing
I was looking at TTS data logs and sensors were all over the place
one of the things I considered was fuel pressure
I swapped in another fuel pump
no difference
I put mine back in and engine wouldn't start at all (but did turn over)
I went back to basics
check spark and fuel
thought I had fuel because I could hear the fuel pump prime
checked spark
spark at both cylinders
is fuel getting to injectors?
checked fuel pressure
zero
found the hose in the tank disconnected
fixed the hose and checked fuel pressure at 55-60psi
back to ecm
got some advice off site
ecm was stuffed
You still think you have fried ecm ?
but not confirmed ?
no difference
checked spark
zero
back to ecm
ecm was stuffed
but not confirmed ?
#54
#55
I had actually just changed the crank position sensor just before I read this. I had a new one hanging on the garage wall from a misdiagnosis from a year or 2 ago. So I thought I'll just chuck it in and see what happens - nothing, is what happened, still no start, still no fuel pump.
I haven't checked spark because it has started twice now, if only for a few seconds and that coincides directly with the fuel pump running or not. So I'm fairly confident spark is fine.
I appreciate the ideas though, we are definitely narrowing it down!
Thanks, Matt.
Thanks, Matt.
with fuel pump working
when fuel pump is not working
#58
#59
https://www.hdforums.com/forum/showt...8#post15706678
I was too lazy to retype it, but the sentiment is the same! So in conclusion, the ECM was definitely fried!!
Thanks guys, Matt.
Thanks guys, Matt.
Big Dave (11-25-2016)
AMB2710
10-11-2021 10:45 AM
