30a Circuit Breaker
Any suggestions greatly appreciated. Sorry if it was a bit long winded!
Thanks, Matt.
Cheers.
'06 NT, 95", S&S .510g, V&H BR 2-2, K&N AC, P&P Heads, SEPST.
You may want to read these two threads as well.
Post #16 in this one:
https://www.hdforums.com/forum/softa...breaker-2.html
http://harleytechtalk.org/htt/index....c,23854.0.html
Seems like Harley replaced the circuit breaker with a 40 amp maxi-fuse in 2007. Some people are retrofitting their rides with the new type fuse.
Checked fuses all ok. While I had the fuses out I thought Id chuck the meter on.
Headlight 12.71v
Fuel Pump 0.00v
ECM 1.15v
I can understand if I messed something up in the tank when I was in there, left a plug off or something, I'm 99.9% sure I didn't. But what I don't get is the 1.15v to the ECM.
WTF is going on???
Also after a quick search of the forum here, my understanding now is that power to fuel pump is cut if the CKP can't detect the motor turning. Again not entirely sure.
I'm getting desperate here, I really don't want to trailer it to those thieving bastards down the road to fix it!!
Thanks
I still have a short somewhere, don't I??
Do you have the schematics? if not look at these and see if they are relevant to your bike.
Re-read your original post and see you do have schematics.
Reading through the links Larsfum gave I would replace the CB with a fuse and ohm out the wires that go to and from the CB, wiggle while checking, (I'd Replace them if I changed to a fuse). Make sure your battery is charged and in good shape, load test it. Check your ground connections 1&2 and 3.
With the ignition off you should have 12V to ground at both the Battery, ECM fuse and the Common of the System Relay. You can check the ECM fuse voltage at the ECM by disconnecting 78 A-B and checking the BE/GY wire at the connector slot 31 in the drawing I posted. Pull the system relay and you should have 12V from the ECM fuse at the Common lug, it supplies the 12V to the fuel pump when the system relay is energized.
Battery Fuse supplies 12V to TSSM and can be checked at connector 30A-B.
When you turn the Ignition on the R/GY and R/BK wire from the switch to the fuse block are energized. The Ignition fuse GY wire sends 12V to the TSSM and to the run/stop switch at the right hand controls. When the switch is put in the run position it supplies 12V W/BK to the Start Button, ECM Switch Power and to the coil of the System relay. The ECM provides the ground for the system relay GN/O for 2 seconds, ( fuel pump will run), and if there is no input from CKP sensor the ground from ECM opens shutting the Fuel pump off. When the System Relay is engaged the ECM 12V energizes the Y/GN wire that provides 12V to the Fuel Pump fuse, Fuel Injectors and Ignition Coil.
Hope this helps, make some checks and let us know what you find.
Bill
Thanks, Matt.
