Red key Idiot light stays on
I replaced my stock directionals (both front and rears) with LEDs and now when I start the bike up the red key idiot light (security alarm indicator) comes on and stays on.
Also the high beam indicator shows some light through it even when the high beams aren't on.
Any ideas? I am stumped!
RE: Red key Idiot light stays on
Last year same thing happen to me . The red key light stayed on after not ride my bike for 3 weeks. Dealer said it throw a code had to redown load on it . The on boarddionastist indcatated speedo had problems . dealer reset it said speedo had problems but if it happen again we would have to replace it. I have on 04 FLHT and I don't even have a securitysystem on bike.Idon't know if this if this will help or not. So far this year (knock wood) I haven't had a problem .
I had the same problem whenI switched to LEDS. I had to adda load equalizer that was compatable with the HDsecurity system (TSSM?) even though my bike doesn't have one. My"red key"came on because bike would generateDT codes B1121 & B1122 (left and right directional fault.)
ORIGINAL: cjuetten
there are two places trouble codes are stored. the ECM and the TSSM. when you have an ECM trouble code, the engine light comes on, when you have a TSSM code the key light comes on. With LEDs you should really use a load EQ per set of T/S. one for the front and one for the rear. more that likely if you install these, and have the codes cleared, the light will go out. otherwise if everything works correctly, i.e. the signals flash, dont worry about it unless the little red light really bugs you.
ORIGINAL: BB06FLHX
Problem is I have an equalizer for the rears (fronts blinked same as stocks).
Did you disconnect the battery when installing the LED's? If so, I'd try to reprogram the alarm security code using the instructions in the owners manual. The reason I mention this is because I recently had to remove my battery and when I reinstalled it I had the security alarm indicator come on and stay on until I reprogrammed the alarm code. I too have LED's on mine and there are a few codes generated because of that. The local dealer said it is not a problem so I have decided to not worry about the codes.
Thanks for the advice. I will try and re-program the bike since I did disconnect the battery before installing the LEDs and not after. If that doesn't work then I guess I will get the TSSM equalizer (yes the red light does bug me). Any thoughts about the high beam light shining even if it isn't on? (it is dim when the light is dim).
