"no rsp" from ECM?!?
Old 06-29-2008, 12:00 AM
BluBob's Avatar
BluBob
BluBob is offline
Default "no rsp" from ECM?!?
When checking codes I get "no rsp" in the first diagnostics module, P (ECM).&nbsp\\; I get valid codes or no codes from other modules.&nbsp\\; The bike is running, and running smoothly.&nbsp\\; How is this possible?&nbsp\\; Recently I have disconnected the dash to remove the tank, and also disconnected the left and right hand control wiring to swap bars.&nbsp\\; I checked all connections, and they are sound.&nbsp\\; Do I need to open the neck and start tracing wiring?&nbsp\\; A kink in the main connector going to the instument array?
Old 06-29-2008, 12:17 AM
rjrivero's Avatar
rjrivero
rjrivero is offline
Default RE: "\\;no rsp"\\; from ECM?!?
No.&nbsp\\; You just need to flip the run/stop switch to "Run" when you're checking codes. \\
Old 06-29-2008, 12:38 AM
BluBob's Avatar
BluBob
BluBob is offline
Default RE: "\\\\\\;no rsp"\\\\\\; from ECM?!?
rjrivero,
&nbsp\\;&nbsp\\; Thanks, that was it.&nbsp\\; I was trying to juggle too much stuff at once.&nbsp\\; I appreciate the help.
Blubob
txphatboy
07-13-2018 06:04 PM
apehangerjoe
08-06-2017 10:03 AM
kyBriar
10-27-2013 07:24 PM
leachman
06-10-2012 10:54 AM
Georgepty
04-13-2012 02:43 PM
Quick Reply: "no rsp" from ECM?!?
