Air intake Solenoid Eliminator
Old 01-12-2009, 03:10 AM
Babe's Avatar
Babe
Babe is offline
Default Air intake Solenoid Eliminator
I've replaced my stock air filter, and connected resistors of various values (18, 20 ohm & an aftermarket eliminator) across the solenoid socket to remove the error code P0661 from the ECU, without success. The alarm can be cleared before I start the engine, but a few seconds after start-up it reappears, and the connected resistor becomes hot very quickly(I've used 5, 10 & 25 Watt variants). All fuses are intact, and the connector itself is OK. Has anyone encountered a similar problem, or have any ideas as to how to overcome it?
Crackahead
05-14-2019 07:16 AM
fatrob74
05-07-2016 02:47 AM
tripleb1911
09-19-2014 03:53 PM
donf610
05-23-2010 11:28 AM
yodal
08-13-2005 03:06 AM
Quick Reply: Air intake Solenoid Eliminator
