"ignition module" Help Needed!
i have sportster 2001 and had problem on ignition module. its need to be changed. there was a sticker on my old ignition module "32465-98 02329"
how, where can i find a new ignition module, i need? i also want to be sure, the part i am gonna buy will work without a problem. i want to buy it online, coz it seems it will be really cheaper. just need a guide to show me where and how can i find that part.
thank you.
thank you.
Many suppliers of after market ignition modules. Loads of suppliers depending on what you want.
Stock Harley modules can be found at any Harley parts suppliers.
Stock module around $225. After market range from there and more depending on what features you want in an ignition module.
An after market module allows for many adjustments beyond the limits set when using a stock module.
BUT ... the module is the most expensive part of the ignition system and any one of the parts can give you symptoms that could be any of the parts from the least expensive breaker, to the coil, to the cam sensor, and finally the module. Plugs and plug wires also can give ignition troubles.
Don't just buy a module if you are not certain that the other components are perfect. Just cause there's no spark does not point to the module.
I'm not certain who ships to Turkey.
Here is just one of many vendors of official Harley parts.
bikebandit
Maybe google will get you a company to ship to you?
bikebandit
Search here with part number 32465-98B.
https://shop.zanottimotor.com/catalo...?sku=32465-98B
Is your bike carburetor equipped or fuel injected?
Would this help?
https://www.surdyke.com/AdvPartInfo....mber=32465-98B
I have a 2001 Sportster 883 CA and we've replaced the coil, which our old one reads the same as the new, the voltage regulator, and ignition relay switch spark plugs too, and we still don't have any spark. Do we buy an ignition Module or what else?
Tired of dealing with this Fing bike. It hasn't been tipped over, it just rolls and rolls and no fire.
Thanks for any help..
