Advice needed
Advice needed
I have a 98 evo. SE pistions and heads, ev-27, mikuni 42 and SE ignition module and coil.
I had to change the cam cover out and noticed that the cam sensor plate appears to be melted by the wiring harness. Not sure if it is infact melted or suppose to look like that.
A friend of mine gave me a Crane HI4 single fire ignition system that he had in his shop. I've read pros and cons about the Crane. My question, should I stick with the stock set up and just get another sensor from HD? or wire in the Crane? Any advantages to the Crane over the stock.
Thanks in advance for your opinions.
Mark
Mark
