My bike broke down
My bike broke down
Hi,
Yesterday my bike started playing up. I have a 2011 Ultra Limited and it started spluttering a little which gradually got worse. the bike needed more and more refs to keep running and it also started to sound 'wrong' and very loud (over and above the revving). I stopped for 30 minuted and then started it and appeared fine but after 20 miles the process started all over again. Eventually I managed to 'limp' home but have no idea what kind of problem I am faced with. Not looking for an online solution but would interested in opinion as to what this may be.
Thanks
Vincent.
Thanks
Vincent.
these are the things I would look at:
dirty IAC
clogged fuel filter
pinhole in fuel line inside tank
bad battery and ground connections
bad gas
fuel pump relay connections are dirty, or relay is bad
More info would help, like how many miles, was it just serviced, any mods, do you have a tuner? Color? (just kidding)
dirty IAC
clogged fuel filter
bad gas
Hi all,
the bike has done just over 19000 miles and was serviced 2 months and approx 1000 miles ago. No tuner and other than some electrical (lights and sound) and cosmetic mods nothing that has not been in place for some time. I bought it 2nd hand, 2 years ago with a 'stage one' tune and H&V pipes.
To the OP- before you go buying something you need to get this cleared up. Whatever is causing your problem most likely won't be fixed by adding something to the mix. Either the dealer is blowing smoke (and is trying to make some money), doesn't know what they are doing or you are not getting us the whole story.
