Starter Grinds--Why?
I have a 2007 Dyna. Usually when I hit the starter it grinds a couple of times before it starts. My professional mechanic has 40 years of experience with Harleys and he tells me that there's nothing wrong and that some Harleys just do that. He would not be shy about telling me I need to pay him to repair or replace a part if he believed that was needed. Any ideas about what's causing the grinding?
Sometimes they grind but always for a reason. Could be weak battery or bad connection, loose starter, missing/damaged teeth, or a couple other things.
In another thread it was suggested to read service bulletin M-1231, which states that all 2006 dynas and all 2007 dynas, touring and softail models are subject to developing erratic starting or grinding during starting as a result the starter fasteners losing clamp load.
I'm not sure of the dyna models have a compensator like the touring models, but in my touring 07 it was the compensator that failed and needed replacing. Fix is to upgrade to the SE compensator. Common failure in tgouring model bikes, not sure about the dynas.
Yes, I am describing a noise. It struggles to start then screeches. After 2 or 3 attempts it starts right up. BTW, I had the service bulletin fix described in my message above and it did not help.
My guess is your battery is worn out. Maintenance chargers keep the voltage up but the cold cranking amps fall off. Also, never let up when you hit the start button till it is running. If you hit it three times starting it, it's getting too much fuel. If it's kicking back, it's the battery. If you have a tuner on it, no telling if it's not set correctly. However, mine acts strange ever now and then when parked hot in the sun and I come back to it before it cools off. It usually starts with a bang as it throws starter gear back.
Thanks, Ripsaw. I do have a PC5 on it that was tuned at a HD shop, which is not reassuring to me. I also have a high torque cam on it. I'll stop letting off the starter button before it starts.
