Fuelpak3: Auto Tune and decreased fuel economy
To the original poster. The Fuelpak FP3's AutoTune feature is calibrating the VE Tables (Volumetric Efficiency) of the bike and nothing else. When you selected a basemap to AutoTune off of which did you select?
The AutoTune will help hone-in the map for bikes with slightly different setups than what is offered from our database. The maps that we create in house are created on a dyno. We tune the VE's, ignition, accel enrichment, decel enleanment, rev limit and AFR tables and more. It is highly recommended that you first start with the basemap that we recommend without running the AutoTune right away. The Adaptive Fuel Values of the bike will still make fine adjustments as ride and go through different conditions. If at that point there are still deficiencies within the map, then AutoTune off the V&H map.
stal94gt
14
03-20-2017 05:47 AM
