misfiring and stalling suddenly
Old 08-18-2014, 02:55 PM
Tommy Salmons's Avatar
Tommy Salmons
Tommy Salmons is offline
Stage I
Default misfiring and stalling suddenly
I have a 2005 softail standard that has been running great until friday when it began misfiring and stalling out. It has 26,000 miles on it. I thought I got some bad gas at first so I ran some bg44k through system at friend suggestion. I filled up but still not running well. I changed spark plugs. Still no luck. I read that ecm connector may have gotten water in it so I am currently drying it out. Any other suggestions, alternator, fuel pump, etc?
Old 08-18-2014, 05:35 PM
jpowell490's Avatar
jpowell490
jpowell490 is offline
I thought the 2005 was carb? You sure it is FI?
Old 09-02-2014, 01:11 PM
dodge and harley's Avatar
dodge and harley
dodge and harley is offline
Stage II
My 07 softail quit about the same time. I've been going all over it since no error codes show up. It fires up on one or sometimes both jugs and quits in 1-4 seconds. Either the ECU is shot or it's not keeping fuel pressure.
I finally gave up and put it in the shop today.
Old 09-03-2014, 10:15 PM
dodge and harley
Stage II
It's a fuel regulator problem. I should have bought a guage to test it myself. We Harley owners have to realize the plastic used to build these hoses and regulator housings are junk. Most performance issues that don't throw a code are likely plastic failures in the tank.
Shadow25rg10@hotmail.com
General Topics/Tech Tips
06-11-2017 11:35 AM
Clayvis
08-27-2013 01:54 PM
KevinKruuz
09-18-2012 12:05 PM
DynaDawg09
06-30-2012 08:00 AM
NX Brad
07-26-2011 09:03 PM
Quick Reply: misfiring and stalling suddenly
