Base Map for tuning
Base Map for tuning
I feel like I'm going in circles with tuning a "14 Forty Eight with a SEPST. I have V&H Short Shots and a DK Outlaw AC installed, so full stage 1. And just to clarify, I've read through the sticky thread but it's just gotten too long with 200+ pages.
When starting out....
Load the correct calibration file in the SE software, of course. I got that but should any changes be made to it before any tuning runs? For example, should any adjustments be made to the AFR since most of the values in the table are 14.6 or is that rich enough vs the stock table? What about adjusting for ethanol?
Tuning runs...
All tuning runs should be made against the base map that's loaded, correct? In other words, I should flash the ECM with the stage I file and then do data runs to add to the original map.
For example, If I've flashed the ECM and make four tuning runs. All four runs should be loaded in Smart Tune for each cylinder, generate and then update all at once. If I run a fifth and sixth, should I be loading all tuning runs and doing the same thing?
If I'm understanding this correctly, it seems to me that if you take a base map, call it A, add some data runs and make changes to it, you essentially make a new base map, call it B, to work from. So should future data runs be loaded into the new one, B, with the previous runs already applied or should A be loaded and then all new and old runs applied at the same time?
Lastly, on tuning runs, information gathered on each doesn't have to be complete, correct? So, if I get out and do some 1-3 gears, save and download, I can add more later and the holes will get filled in by the computer or is it better to get the full range on each run?
Any help would be appreciated.
Tuning runs...
Tuning runs...
Tuning runs...
Looking for 103 in 204 cam base map
Hi all
Just had my 2011 FLHTK 103 rebuilt completely.
I had 204 cams installed and can't find a base map for the 204 cams
Want to use my SE ProTuner smart tune but as I understand it I need to find a base map as close to my engine as possible.
103 stock
SE Air intake
SE Exhaust
204 cams
All else is stock.
Any help or suggestion would be greatly appreciated.
Bob
103 stock
SE Air intake
SE Exhaust
204 cams
All else is stock.
Bob
Need to know what base calibration to start with
Hopefully this doesn't sound too stupid, but I just installed an SE intake...the one that uses the OEM intake cover. I have a 2014 Ultra....basic, nothing but Rinehart slipons. What base calibration should I start with. The closest was "617SEN204", but that has a SE exhaust, which I do not have...will this make a difference? The next question is...what calibration should I use after I install the Slimline Duals from Rinehart
My plan is to get the bike Dyno'd, but I wanted to play with the tuning a bit myself...and maybe learn something. I also wanted to know how to set the calibration back to factory.
Thanks
Thanks
stuboy-2001
02-02-2015 05:58 AM
