Ironhead A place to talk about Ironheads.
1978 Ironhead
Old 07-19-2015, 09:46 PM
Wcm71's Avatar
Wcm71
Wcm71 is offline
Default 1978 Ironhead
hey guys I have an issue with driving down the road yesterday and my sporty jumped out of gear . Tried to put it back in gear and it would not go in gear. Shifter very hard to shift down or up but will not engage in gears any ideas?
Old 07-19-2015, 10:25 PM
Frigeratorman's Avatar
Frigeratorman
Frigeratorman is offline
Sounds like the shifter arm has broken or the pin that holds it to the shaft has sheared.
You'll need to pull the transmission to find out exactly what's wrong, so my advice is to get the Factory Service Manual and a Factory Parts Manual to engage any further.
This makes everything about doing a job like this a LOT easier.
You can also find a good,reputable independent that will work on an Iron Sporty to fix it for you,but be prepared to pay $$$.
Old 07-20-2015, 02:58 AM
Hopper's Avatar
Hopper
Hopper is offline
What gear was it in?
Before you do anything internal, check that the gear lever is not hitting the footpeg mount on the upstroke before the gearbox has fully shifted to the next higher gear. If so, move the gear leaver down by one spline on the shaft. This is a common problem with 77 and onward Ironheads.
Old 07-20-2015, 05:36 AM
IronMick's Avatar
IronMick
IronMick is offline
It may be a long shot but do a clutch adjustment also. Follow the factory manual. It is a complicated 5-step procedure to do it correctly, with some steps being whole paragraphs. Do a Google search for "ironhead clutch adjustment".
SixDD
05-10-2019 06:08 AM
jqb12
08-27-2017 10:44 PM
OddJack
09-28-2014 05:47 PM
bergys
Ironhead
02-03-2010 10:14 PM
AND
Ironhead
14
08-04-2009 07:08 PM
Quick Reply: 1978 Ironhead
