84 ironhead wont idle
I have a 1984 ironhead sporty that wont idle.the guy I got it from had the carb off for rebuild and it sat in a barn for 2 years.I have put the carb back on,new pecock ,plugs,wires ,inline fuel filter can not find any adjustments on carb other then idle adjustment which does not help any.
RE: 84 ironhead wont idle
If it has the stock carb. the idle mixture screw should be on top at the rear of the body. There may be a plug over the mixture screw, but if it has been rebuilt (properly) the plug should have been removed. also do not forget that a vacuum leak at the intake seals will cause a poor idle problem.
If that carb was off for a rebuild it's possible that something was assembled wrong or there is a part missing. I'd take it back off, break it down and compare the parts with the diagram in a shop manual to make sure everything is there. With the manual you can check your float settings, etc.
