points and condenser
bike is bogging again. runs fine as long as I'm out of the throttle. I think it may be the condenser...I noticed while running the bike with the points cover off what looked like some serious arching from the points while the bike was running. Thought that the condenser wasthere to keep this from happening. Also, have been told from some old timers that you can run blue streak points and condensors from an old ford in an ironhead...if this is true can anybody tell me what kind of car I should ask for at the auto parts store. The local dealership is out of them. Thanks.
RE: points and condenser
Found it..changed the condenser. The Harley Blue Streak points and condensornumber on the back of the points cross to an old Chevy number. Changed the condensor and cleaned(covered with black soot) and regapped the plugs. Runs great. Adding small wire brush, sand paper to the tools in the bag...will pick up and extra set of points and a condenser to throw in the bag too as nobody but the local car parts store can get me one without ordering it.
Well.......I don't know about that. Run the bike for a few miles and see what happens. If you wind up with sooty black spark plugs again and bogging problems, then I believe your trouble lies within the carb, not the ignition.
The ignition points spark because the electrical field is broken everytime they open. I consider this normal. The purpose of the condenser is to provide a quick collapse of the magnetic field in the coil which then produces the (high voltage) spark to the spark plugs.
But, maybe I am wrong about your trouble...............pg
Received 1,211 Likes
Actually the purpose of the condenser is two-fold - One, it extends the length of the collapsing field by virtue of it forming an LC circuilt (coil & capacitor), and two, it prevents the point contacts from burning caused by the arc that happens when the coil field collapses. If you see excessive arcing across the points, then it will be a bad condenser, and the timing will be altered as the coil collapse occurs later than it should due current still flowing thru the arc across the points. The spark produced will be weaker than normal as the field collapse occurs over a longer time.
Daniel Miller
07-07-2015 11:52 AM
zenwarrior
09-13-2006 01:17 PM
