84 clutch adjust
84 clutch adjust
is 84 clutch adjust procedure the same as in the other thread that piniongear illustrated ??/ the reason I'm asking is when I replaced the primary cover and adjusted the clutch I got slippage (almost new clutch) I turned the adjuster screw (at the cover) inward and the slip went away, that dont seem right
piniongear's list of steps for adjusting the clutch is usually considered to be the best.
Near the end there is a step where you turn the adjusting screw out 1/8 to 1/4 turn in order to set the free play at the hand lever. I do it like this - turn it out 1/8, check free play, if good then done otherwise turn it out a little more, etc.
Tampa Fatboy
04-04-2023 08:35 PM
Talldog
07-31-2014 05:08 PM
