Battery tender harness and fuse location?
Old 12-19-2016, 08:46 PM
SWThomas's Avatar
SWThomas
SWThomas is offline
Default Battery tender harness and fuse location?
I got an adapter harness for my heated gloves that allows me to power them using the battery tender plug on the bike. My understanding is that the battery tender harness has a 5A fuse, and the harnesses for heated gear generally run a 10A fuse. Does anyone know where the fuse for the battery tender harness is? Normally it's an inline fuse when you install one yourself. But the bikes come with the tender harnesses installed from the factory. Is the fuse still inline or is it in the fuse panel? If it's in the panel, which one is it? The only thing I could find in the fuse diagram is "battery" which is a 5A.
Thanks!
Old 12-19-2016, 08:56 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,924 Likes on 3,022 Posts
That's probably it, the main fuse is a 40amp on the new bike. To test my theory plug in the tender check the tender light, then pull the fuse and see if the tender light goes off.
Old 12-19-2016, 10:31 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,543 Likes on 4,431 Posts
I believe the 5A is correct because it says when using a battery tender it needs to be 5 Amps or less. I don't believe the battery tender harness is intended to use for heated gear. I never used heated gear but had some friends that have and blew fuses, and were told not to increase the fuses to avoid that from recurring and could cause a fire. Under the impression that heated gear comes with instructions and optional battery connection hardware, harnesses with inline fuses, etc. Best bet obviously is to discuss this with the service experts at a dealership, or if your gloves aren't HD brand go talk to the folks in Motorclothes department and ask to look at the instructions for a pair of HD gloves. Bet that would tell you what you need.
don't see the instructions on their site but they sure provide a lot of 'stuff' to connect them with
http://www.harley-davidson.com/store...-in-12v-gloves
Old 12-20-2016, 02:19 AM
paullavery's Avatar
paullavery
paullavery is offline
My Gebring heated gloves have their own in line fuse & connectors that go straight to the battery terminals. Also I use an optimate charger & always connect the supplied in line fuse connector directly to the battery, so the factory fitted connector is always redundant.
Old 12-20-2016, 05:06 AM
SWThomas's Avatar
SWThomas
SWThomas is offline
Thanks for the info fellas. I have a set of HD gloves that I use but I left the harness for them on the old scoot when I sold it. So I was just trying to see if I could use what was already on the bike (battery tender) without having to add more wires to the battery. But I'll just go the safe route and order a new heated gear harness.
Old 12-20-2016, 01:41 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Battery Harness
The battery harness for Gerbings heated gear uses a 15a fuse.
Old 12-20-2016, 07:42 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is online now
IIRC on the 2014-2016 touring bikes, the factory battery tender is powered thru the P&A fuse which is a 20 Amp fuse. I can't say for sure that this is the case for the 2017 models. As for the gloves, many draw 2.2 amps so a 5 amp fuse should work fine. I use a pair of heated gloves & a jacket liner with a 10 amp fuse in a separate lead direct to the battery.
Old 12-20-2016, 08:06 PM
mjwebb's Avatar
mjwebb
I saw that in my 2017 manual:
"When using the factory installed battery tender connector, the main fuse and P&A fuse (20 Amp) must both be installed."
then I saw this:
"An automatic, constant monitoring battery charger/tender with a charging rate of 5 amps or less at less than 14.6 volts is recommended."
I'm too stupid with electronics to piece it together enough to be hooking stuff up to it
slowrollin (12-31-2017)
Old 12-20-2016, 08:28 PM
14GuineaPig
RevZilla has a video that explains about a separate lead direct to the battery and what size fuse to use depending on what gear you're running.
http://www.revzilla.com/motorcycle/g...attery-harness
Old 12-22-2016, 10:49 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
I have used the battery tender cord to power up my tire pump, I know lots of folks use it for heated gear as well.
Quick Reply: Battery tender harness and fuse location?
