Strange mix of bolts/nuts
Old 03-07-2017, 03:20 PM
strat10's Avatar
strat10
strat10 is offline
Default Strange mix of bolts/nuts
Just got done installing some slipons and pipe covers on my 17 RGS. Anyone else notice that Harley uses a strange mix of english/metric bolts. Not only english/metric, but a strange mix of Torx and hex heads.
My Ducati, and KTM are all metric.
Not bitching, just find it strange, and a bit of a pain in the *** when you are grabbing tools.
Old 03-07-2017, 05:38 PM
bicard's Avatar
bicard
bicard is offline
yep, noticed that when I put my saddlebag guard bars on... didn't make sense...
Bob
Old 03-07-2017, 05:39 PM
purpledeuce's Avatar
purpledeuce
purpledeuce is offline
The MOCO likely does it to push folks to use the dealer for the install. It's no different than a car manufacture designing things so you have to remove the wheels in order to change a headlight bulb
Old 03-07-2017, 05:47 PM
YPD485's Avatar
YPD485
YPD485 is offline
The previous 2014-2016 bikes are the same way. So it's not new for 2017.
Old 03-07-2017, 08:41 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,257 Likes on 3,628 Posts
From what I see, HD is slowly replacing SAE fasteners with metric as they produce newer parts. They still use a bunch from the older bikes.. I figure by year 2100 it will be all metric.
Old 03-08-2017, 01:21 PM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Received 1,807 Likes on 627 Posts
You think that soon lol
Old 03-08-2017, 02:59 PM
bicard's Avatar
bicard
bicard is offline
I didn't get into my 16 RGS, so I didn't know.
Old 03-08-2017, 03:04 PM
BrokenAnchor's Avatar
BrokenAnchor
BrokenAnchor is offline
I noticed the same thing. I just installed 14" Yaffe Monkey Bars and had to remove the outer fairing, the gas tank, the right side panel and the right side exhaust to run new cables for the clutch and front brake. I was switching between standard and imperial tools all the time as well as Torx to Allen Keys. Kind of a pain in the **** but I have all the tools anyways. Just more trips back and forth to the tool box.
Old 03-08-2017, 03:20 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
In the back of the parts manuals every year there's a section that lists the components by part number and type and lists the year that part was first used. I get a kick outta looking through it every new model year.
I think the oldest part I saw on the M8 tourers was a retaining ring that's listed as being used since 1936
Old 03-08-2017, 07:38 PM
strat10's Avatar
strat10
strat10 is offline
1936! thats funny
Quick Reply: Strange mix of bolts/nuts
