help! check engine light is driving me crazy!
Hey Folks, I have a 99 Dyna that has the check engine light on...Continuously! Problem is I have no idea why. I've done the test to get codes 3 times now. All I get Is d01Clr (1-11) Then Cal 09. When I restart the bike the engine light actually clears for about 3 seconds then comes back on. According to what I'm reading if its throwing a code I should see something else. Help Please??
Have you checked the ground from voltage regulator? It can be just slightly loose and cause the check light to come on.
Received 47,791 Likes
Hey Thanks, Mick, for your response. I wish your suggestion was the fixer but everything is secure. No loose, frayed, or fried wires. I must admit this issue, I think, occured when the cam went bad years ago. Can got fixed bike ran great. Just figured the check engine light didnt reset itself. Now it's bugging me! Still runs great.
You may have better luck posting your question in this thread...
https://www.hdforums.com/forum/elect...ting-alarm-43/
Not sure on 99 models but earlier models are different. try what this thread says and see if it works for 00-03 Welcome as well.
https://www.hdforums.com/forum/softa...des-dtc-s.html
When the light comes back on means it still has the problem that throws the code. MORE DIGGING !! HA !
Ride Safe Rode Often !
