Gerbing heated gear and the CanBus system
I've been looking into some heated gear and watched a video on Revzillas sight. It said there would be issues if heated gear was plugged into the 12v power outlets like the one on the fairing and in the tour pak.
Maybe I misunderstood them. All I need to run is a vest and a pair of gloves for myself and my wife. I figured that would be the less expensive route to go rather than the harness mounted to the battery.
Any info or suggestions would be helpful.
I use the Gerbing jacket and gloves and they are connected to the electrical system on my '14 Limited with a direct fused line to the battery. The harness is provided with the heated gear. Used them all last winter with no problems. I can't say how they would work with the fairing or tour pack outlets.
I have Gerbings heated jacket and gloves wired to my 2104 SG. As others have said each piece of clothing comes with a fused connector that you can connect direct to the battery which means it doesn't affect the canbus at all. I don't know about the vest but the jacket has connectors on the sleeves for the gloves, which mean you only need to plug the jacket into the battery connector and then use a dual heat controller so you can regulate the jacket and gloves separately. You will need to work out how you are going to connect the four bits of kit for you and your wife and if the bike can handle that amount of current draw. My thinking on connection would be two battery connectors and then you and/or wife could plug in separate dual temp controllers and plug in vests and gloves. I have a feeling each bit of kit pulls about 5 amps but I'm not sure.
I run my heated jacket liner and gloves off the Rushmore battery tender lead. It's fused at 20a. No need to hook up another harness.
Sent from my iPhone using IB AutoGroup
