2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Fluid change
Old 01-30-2015, 07:24 AM
ultrawing's Avatar
ultrawing
ultrawing is offline
Default Fluid change
2014 limited doing my first oil change on a Harley. Here is what I have. is it the right oils?
1. Lucas motor oil
2.Lucas primary chain case oil
3. Lucas 75-140gear oil for the transmission
Old 01-30-2015, 08:52 AM
Norms 427's Avatar
Norms 427
Norms 427 is offline
Old 01-30-2015, 09:04 AM
Sunnyday91360's Avatar
Sunnyday91360
Sunnyday91360 is offline
Old 01-30-2015, 09:30 AM
ultrawing's Avatar
ultrawing
The question isn't about the brand but the proper oil to use.
Old 01-30-2015, 09:33 AM
plongson's Avatar
plongson
plongson is offline
You are on the right track.
Motor oil in the engine
Primary oil in the primary
Gear lube in the gearbox
Follow that rule and you can't go wrong, been doing the same thing for years...
Old 01-30-2015, 09:43 AM
ultrawing's Avatar
ultrawing
Thanks Plongson. That's the info I needed.
Old 01-30-2015, 09:55 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
1. Lucas motor oil
If your engine oil is 20w50, you'll be just fine.
Twisted Humor
09-23-2022 01:31 PM
babaharley
03-25-2018 03:53 PM
MNtadpole
11-09-2015 07:42 PM
Fat-Bob-Brad
04-03-2011 12:39 PM
cirhere2
04-09-2008 04:23 PM
Quick Reply: Fluid change
