2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Tour pack latch breakdown
Old 02-25-2015, 08:17 AM
gobblerhuntr's Avatar
gobblerhuntr
gobblerhuntr is offline
Default Tour pack latch breakdown
Does anyone know how to break a tour pack latch down? I am looking at getting the latch and hinges powder coated and wonder if it can be torn down. There is some rubber in the latch that will not stand the heat I'm sure. It may not be able to be done but I knew someone here would know. Also the hinge, can it be broken down?
Old 02-25-2015, 09:38 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
I don't know the answer, but if they can't they can be purchased black from HD.
http://www.harley-davidson.com/store...ge---latch-kit
Old 02-25-2015, 10:43 AM
gobblerhuntr
Yeah I was aware that Harley made those. I was wanting to get mine done and save a few bucks.
Old 02-25-2015, 11:20 AM
fzggm4's Avatar
fzggm4
fzggm4 is offline
I am pricing a chopped tour pak and was wondering the same thing. I don't want to spend the additional $ for the HD one's if I can get them powder coated. Subscribed.
Old 02-25-2015, 12:18 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
Did you look at the instruction sheet for the latch? Sometimes it will give you a good look at the parts you're dealing with. Just a thought.
http://www.harley-davidson.com/app-c...ts/-J05715.PDF
Old 02-25-2015, 02:48 PM
gobblerhuntr
Yeah I looked at that and have had the part in my hand. It appears that there may be some pins that are pressed in the latch during assembly that cannot be removed. I was hoping that someone could tell me for sure if these can be torn apart and separated to powder coat.
Old 02-26-2015, 09:27 AM
UltraSteveUSAF's Avatar
UltraSteveUSAF
UltraSteveUSAF is offline
Just having some parts powder coated, rubber isn't the problem, its the little plastic pieces in there. I'm working it. If I find a solution I'll post as of now the plastic will melt if you powder coat as is from what I've been told. I'm hoping to get this cause BLU will be happy with more Blue Powder
Old 02-26-2015, 01:04 PM
craigffb's Avatar
craigffb
craigffb is offline
I wanted to have mine powder coated as well, but after looking over the latch decided it wasn't worth running the risk of trying to break it down in fear of busting something and having to buy a new one.
Old 02-26-2015, 06:56 PM
bigrobtemp's Avatar
bigrobtemp
bigrobtemp is offline
Default no way to do it
As i wrote in the other thread. I tried but ended up not being able to do the latch. I sucked it up and got the kit from moco. Go to kutter harley it was 166 shipped. Cant get the plastic out of it.
Old 02-26-2015, 09:29 PM
FFZHD's Avatar
FFZHD
FFZHD is offline
Send it to Joe at The Powder Pro !!!!!!
A lot cheaper than buying from MOCO !!!!!!
Quick Reply: Tour pack latch breakdown
