Hydraulic clutch question
A few days ago I installed 13 inch apes on my 2015 RGS. The install went fine until the very end when I had to install the controls to the bars. The way the brake and clutch were oriented the banjo bolts on both sides were touching the new bars. I loosened the banjo bolt and shifted the banjo bolts so they cleared the bars. Everything went back together fine but I did get a few drops of fluid from the clutch side. Now whenever I start the bike if it's in 1st gear she jumps forward a little. They already did the clutch recall prior to me doing the bars so I don't think it's the recall issue. It has to be what I did. What's the fix? Do I need to bleed the hydraulic clutch?
TIA
TIA
Unless you accidentally introduced some air into the system, there should be no clutch issue related to your bar swap. Well, unless the line is getting kinked somewhere else down the line.
It is a closed system (the hydraulic clutch), just like a brake system. If a few drops of fluid leak out when you crack it open, that's better than having the opposite happen, getting air in. If air got in, then the lever will have a slightly spongy effect on the clutch actuation. If no air got in, then it will simply self-correct the fluid level from the master cylinder.
Now, the jumping forward a little when cold starting in gear...that's pretty typical.
If the clutch operates well in all other respects, I doubt you've caused any trouble by moving that banjo bolt.
If you're bothered by it though, you can try bleeding the clutch system and seeing if it starts without moving in gear. If yours does that, be very happy.
All the best,
Shane
All the best,
Shane
Some so much that the plates have to break free of each other before the clutch will function at all.
Shane
