2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
HD Saddlebag LED lights- brake lights not working
Old 04-22-2016, 01:48 PM
steve04's Avatar
steve04
steve04 is offline
Default HD Saddlebag LED lights- brake lights not working
I installed these LED lights on my bike but the brake function doesn't work. Running lights and turn signals work but no brake light. Anyone have this problem or a solution to get the brake function working.
Thanks, Steve
Old 04-22-2016, 02:08 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is online now
Received 3,951 Likes on 2,170 Posts
Are you sure you followed the correct wiring schematic?
Old 04-22-2016, 03:56 PM
steve04's Avatar
steve04
steve04 is offline
Yes I connected it per the directions for the FLHTCU. After I didn't get a brake light I also moved it to the other connection in the directions as shown, no light at all in that connection.
Steve
Old 04-22-2016, 04:34 PM
GTK's Avatar
GTK
GTK is offline
If your regular brake lamps are coming on and the new LED's are not,I would think you have a LED module defective in the kit.Make sure you did not bend a pin in a connector when you were hooking the wiring up.
Old 04-23-2016, 05:11 AM
steve04's Avatar
steve04
steve04 is offline
I'll check for pins being bent. After reading on another forum it seems like HD may have the wrong
Module in the box.
Thanks
Steve
Old 04-24-2016, 05:56 PM
twosailin's Avatar
twosailin
twosailin is offline
I seem to remember having this problem. Wrong module! They make three different ones, ultra, road glide and street glide, I believe. I had the SG for my Ultra. One would think they would be the same, but I guess not......John
Old 04-24-2016, 09:00 PM
steve04's Avatar
steve04
steve04 is offline
Thanks John, I think you are right. Seems like I need the module # ending with an "A" that comes in the tour pak removal kit. Going to try the "A" version on Tuesday if the dealer has on.
Steve
Hammerhead59
Screamin Eagle CVO Models
05-18-2017 07:40 AM
Electrotech
11-19-2014 06:50 PM
BirchwhiteHD
06-22-2009 09:00 AM
j33ptj
01-06-2009 06:06 PM
jhogan20
12-03-2007 08:05 PM
Quick Reply: HD Saddlebag LED lights- brake lights not working
