FP3 Wont download map to bike??
Just bit the bullet and bought V&H Power Duals and a FP3 for bike, hooked up the FP3 to bike and done all the pairing stuff and gone to download a map to bike and it goes through...
Map transfer
Connected to VIN *****(my VIN)
Linking,
Sending stock to server,
Checking for available slots,
Transferring Map
3 seconds later it comes up with "process did not complete verify power on/ engine off. please try again. Code 1301"
Power up the App and it says it's not linked to any bike??
Am I missing something here???
I have V&H Power Duals and Std CVO mufflers (put monster rounds with Power Duals on the map)
Map transfer
Linking,
Transferring Map
E-mailed Chris Neely at V&H Customer services, he replied within 30 minutes, advised me to make sure I had the latest IOS operating systems on my Iphone (which I had'nt) gave me advice on which map to use, and it all downloaded to bike FIRST TIME of trying.
That for me is EXCELLENT customer service!!! Cheers Chris.
Ady
Ady
Map transfer
Linking,
Transferring Map
Map transfer
Linking,
Transferring Map
The 1301 error states that the internal chip had timed out, (writing the new map to the internal memory). Upon your upload we noticed that you are running an older version of iOS, (9.2.1). Whereas the current version is 9.3.1. This may be causing an issue. I suggest to update the OS and reflash the bike, also make sure your internet connection has adequate bandwidth and strength otherwise the server could time you out as well. Everything else looked good on our end.
You can also reply to my email as well.
Custardglide (04-29-2016)
I have yet to hear of a FP3 fail that wasn't either user error or something quickly fixed by VH.
Come up with a specific problem. Tell VH about it, and give them a chance to respond. Until then, don't sour someone else's experience with your impatience.
GM
GM
_Wotto_ (06-25-2022)
Sure did, but y'all stay in denial. Ive clearly outined issues ive had. I am entitled to my opinion and voice. This still is America right? As an update i had problems with both units, original and replacement. Technicians werent knowledgeable and none if their suggestions fixed the issues. And again I've had an FP3 on my dyna since 2013. Not user error.
