don't start throwing rocks yet ! this is not about what kind of oil, but what weight you are running in your twinkie. i know thw owners manual says you can use 60 weight, but how many are ?
Not using straight 60, but using Liqui-Moly 10w-60. Ran it in my 12 RGU, just switched over my current bike also. There is a thread over on HTT, extensive read. For me it helped quiet the 12 motor down a bit. That bike didn't like Mobil 1.
I use Spectro 25-60 dino oil... best I've found.
Mobil 1 20-50 is the worst I've tried as far as noise... nothing else comes close.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I've ran HD 360, Valvoline VR-1 20/50(conv), Brad Penn HP 20/50, Mobil1 V-Twin 20/50 and they all sounded the same and recorded oil temp numbers similar(within 3 degrees, IR gun used) of the oil they replaced on the same day, same loop, same everything. Have Redline 20/60 on hand for this summer only due to the fact that with 11.5-1 compression now I expect to be running a bit hotter than before so I was thinking a 60 viscosity would be better, I guess I'll see if it is, LOL.
You might want to re-read the manual if you think you can run 60 weight in your engine.
I did see the manual states I could run SAE 60 above 80* also. I still use 20W50 and will continue to do so. I'd run it if I was riding in hotter weather but I prefer to ride when it's cooler.
