2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
FillerZ installed. But guage turn signal blinks very fast
Old 06-25-2016, 03:25 PM
striper.seeker's Avatar
striper.seeker
striper.seeker is offline
Default FillerZ installed. But guage turn signal blinks very fast
Just finished the install of the CD FillerZ on my 2015 FLHTK and the look great. For some reason the turn signal arrow on the guages blink very fast, like what happens when a bulb is burned out or there is no equalizer. The 2014 and up are not supposed to require the equalizer for LEDs. I also have the RingZ up front. Both operate the way they should but I'm worried somethis is amiss with the arrows blinking so fast.
Did I do something wrong? Is this normal?
Any advice would be great.
Thanks
Old 06-25-2016, 03:42 PM
striper.seeker
Found the thread. Thanks.
Old 06-26-2016, 06:56 AM
K Melancon's Avatar
K Melancon
K Melancon is offline
Turn your emergency flashers on for 5 minutes then you should be good.
Old 06-26-2016, 07:13 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,622 Likes on 5,178 Posts
There you go won't even take that long . The CANBUS will reprogram and good to go.
Old 06-27-2016, 08:16 PM
pswomack's Avatar
pswomack
pswomack is offline
If turning the hazards on for 5min doesn't work, try this:
Start the bike
Turn the hazards on
Let it idle for 4-5 min
Turned the ignition off while leaving the hazards on
Turned the ignition on and then turned hazards off
Turned ignition off and then back on
Both Turn signals should work correctly after doing this.
DougYITBOS
05-22-2013 12:26 PM
W1ldC4t
11-27-2012 05:08 PM
OldFenderGuy
06-04-2011 01:07 PM
gilyoyo
11-01-2010 03:07 AM
sr71gn
07-12-2008 04:09 PM
Quick Reply: FillerZ installed. But guage turn signal blinks very fast
