Trunk LED Lights wont turn off??
woodmnctry (07-11-2016)
No --- its the red LED running lights on the outside of the tour pak on each side on the bottom.
Im now thinking something is wonky with the ignition switch as noted ---as the on/off switch for the fog lights is glowing --- and the fog lights not on.
Could somebody please check and tell me if "when the ignition switch is in the ACC position are the red led running lights on BOTH sides of the outside bottom of the tour pak on?
When in the ACC Position on the Ign. switch, any Accessory light will be illuminated, the side marker lights on the tour pac and rear saddlebag lights along with the Passing Lamp switch light are illuminated on my 2016 Limited when the Ign. Switch is in the ACC position.
Thanks for the help
I'm confused. So these lights stay on with the switch turned off?. Did you get this sorted out?
