2014 FLHTK fork oil change ??
It really is easy to remove them. Maybe a little intimidating to some but their's nothing complicated. You'll need a 19mm (3/4" works also) Allen wrench to remove the fork caps.
A factory service manual is worth it's weight in gold for procedures such as this. Gives you step by step directions as well as torque specifications for fasteners.
So looking at the service schedule it says to "Rebuild" the forks every 50,000 miles, changing oil. Man that seems like a lot of work.
I remember older Honda's I had, had a drain plug on the bottom of the forks which made it easy to change the oil.
My 2005 Goldwing doesn't have that either. They have to be removed from the bike and the fork caps removed and then turn them upside down and drain, (and pump them) to get the oil out.
Why do they make these bikes so much more work to service these days?
Could it be possible to drill a drain hole in the bottom of the forks and then tap a screw in there to seal it?
I am hoping that some one has done it and has engineered a legitimate shortcut or 2 for removing the old fluid and installing the new fluid without taking apart perfectly good forks. I have read the procedure & I am very capable of doing the task however; I would rather use my brain than my back. No "embracing the suck" [lol] unless absolutely necessary...
