2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Ign. switch alignment tool a must???
Old 04-10-2014, 09:38 PM
NWGlide's Avatar
NWGlide
NWGlide is offline
Default Ign. switch alignment tool a must???
My ignition switch got turned while installing new handle bars, and now the **** won't go back in all the way. Is the HD ignition switch alignment tool the only way to re-align it?
Old 04-10-2014, 09:50 PM
alstrud's Avatar
alstrud
alstrud is offline
I've done it with a long, skinny slot screwdriver. Look down through with a flashlight and make sure the grooves line up. This was on a 2008 Ultra, but I'm sure it's the same for a 2014. Good luck...
Old 04-10-2014, 09:55 PM
fftoddster's Avatar
fftoddster
fftoddster is offline
Had same thing happen. Got it with screwdriver and lots of patience and attempts. The tool is different size on the 14's
Old 04-10-2014, 09:59 PM
kishstl's Avatar
kishstl
kishstl is offline
Time, patience and a skinny little screwdriver is all you need.
Old 04-10-2014, 10:27 PM
NWGlide's Avatar
NWGlide
NWGlide is offline
Cool, thanks fellas!
Old 04-11-2014, 05:34 AM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
If you search this forum there are several posts on how to make that tool out of copper tubing.
Old 04-11-2014, 09:38 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Silly me, I used the ignition switch. Just took the spring off of the bottom of it.
Old 04-12-2014, 04:45 PM
TcHunter's Avatar
TcHunter
TcHunter is offline
There is a video on you tube, I think the title is "Why you should lock your Harley"
Old 04-12-2014, 05:45 PM
LilWick's Avatar
LilWick
LilWick is offline
screw driver as others have said. Turn the bars to the left like you would to lock the bars, turn the screw driver counter clockwise one click at a time till the bars lock. Slide the ignition fob in, in the bar lock position and it will go right in. Don't ask me how I know this
Alan
Old 04-13-2014, 10:30 AM
NWGlide's Avatar
NWGlide
NWGlide is offline
I ended up using the 1/4" copper tubing like the video. Just lightly hammer about 3" of it flat 'till it's approximately 5/16" wide and bend the top over to a 90 degree angle.
Quick Reply: Ign. switch alignment tool a must???
