Softail oil feed line - weeping
The oil feed line weeps at the black rubber hose. Has anyone else had this problem and how did you fix the weep? I have a new hose and wonder which clamp to use. Thanks.
RE: Softail oil feed line - weeping
Not sure of exact name but one of the permanent pinch clamp that H-D uses. I have screw clamps I could use but there are also the wire loop clamps.
atomic928
02-19-2010 11:08 AM
